Need to know
Old Oct 14, 2009 | 12:35 PM
DWILSON's Avatar
Default Need to know
I have a 2004 Monte Carlo SS and over the summer there was something wrong with my air conditioning. All it would blow out was hot air. So I took it to the Chevy dealer in my area and they said that it was only a component in the condenser that they fixed. Now that it's getting cold, my car will not blow out heat at all. Second, would antifreeze have anything to do with why my blower is blowing out cold air?
Old Oct 14, 2009 | 12:59 PM
What's wrong with your anti-freeze?
Old Oct 14, 2009 | 04:01 PM
DWILSON's Avatar
I looked under my hood one day and there was nothing in the resavoir... went to AutoZone and got the already mixed all car all weather and now it looks like there is nothing but water in my resavoir and I have no heat blowing out of the blower just cold air.
Old Oct 14, 2009 | 08:51 PM
Scooby doo's Avatar
I would be more worried about mixing DEXCOOL with an non DEXCOOL friendly antifreeze than I would be worried about heat right not.
Might want to get the cooling system drained, flushed and refilled with the proper ratio of anti freeze and water pronto. If you do it yourself I would use distilled water.
As for the heat, heat is provided by running hot coolant from the engine through a mini radiator (heater core) while running a blower through the heater core and into the car.
Could be a thermostat problem, car not heating up and therefore you are not getting hot coolant to the heater core, so is your car warming up to operating temp?
Could be the heater control valve, not sure where these are on these cars but usually somewhere in the heater lines there is a valve that depending on where you put the temp dial controls the flow of hot coolant to the heater core.
Let us know what you find, and make sure you have compatible coolants in your car, what was there, and what you added.
DEXCOOL can be a nasty thing. I have pulled it out of both my GM cars.
STUMPMI
Oct 9, 2013 09:03 AM
eric.parent
Apr 22, 2011 06:14 PM
Scooby doo
Apr 1, 2010 08:59 PM
rj
Apr 3, 2009 05:56 PM
rollie_tatro16@yahoo
May 24, 2008 08:13 PM
