Need help fast!!!!! Car won't start
When i put the key in the ignition and turn to acc the gauges and my lights all turn on and work but, when i try to start everything goes out and nothing happens complete silence. There's days that it starts with no problem but lately it just doesnt want to start. please help me!!
i just graduated from high school and start college in a couple days and its my ride. Please help. Thank you!!
Sounds like a bad starter, it was probably just intermittent but now it's more than likely shot. How many miles are on your car? I've seen that happen to quite a few of these engines around 60xxx-90000 miles.
Try tapping on the starter with a hammer (you can get to it from under your car). That will only work a few times, so I'd have it looked at soon
You shouldn't fry anything unless you're doing something wrong or jumping it where it shouldn't be jumped.
Yeah it could definitely be the battery... but unless the battery is nearly dead it should at least push some juice to the starter. It would at least try and crank, not just sit dead and do nothing. When it's being cranked the battery is putting out as much as it can to get the starter going, therefore leading everything in your car to turn off when you try... And if you're not getting any crank from the starter and keep trying, eventually the battery will die from trying too much.
I guess I usually assume people try and jump the car
Hows the battery cable and connections, no residue buildup around the battery hookup at positive? Also check the wires to make sure no insulation missing anywhere, but I've had the residue buildup definitely do this on quite a few of my cars over the years!!!
Mike
Mike
