6th Gen ('00-'05): Need help! August in Miami with no A/C is killer.
Old Aug 15, 2014 | 04:19 PM
thewhitestcarlouknow's Avatar
Default Need help! August in Miami with no A/C is killer.
I have an 02 monte carlo ss. I recently replaced the radiator fans. When I got the car put back together, the fans were not kicking on. At one point, I tested the connector at the fan motor and was getting plenty of power to the fan motor. However, I am now getting no power to the motors. I have checked the fuses and the relays and both seem to be fine. I do not know where to go from here. Any help would be greatly appreciated.
Old Aug 15, 2014 | 08:45 PM
vincenti's Avatar
Rechecked the wiring? Made sure the grounds & everything were good?
Old Aug 15, 2014 | 09:57 PM
Aaron0313's Avatar
How is the ground point for the cooling fan system (G108) which is located at the left side of the radiator support? I found this wiring diagram, it might be of some help to you.Ybof53d.png
Old Aug 16, 2014 | 08:01 AM
Thanks for the help guys I will try a few things. I haven't been able to locate the ground. When it says left side of radiator support is that the driver's side or passenger's side? Any idea what it looks like?
Old Aug 16, 2014 | 01:20 PM
Aaron0313's Avatar
Left would be driver side. You could also just continuity check the black wire off of fan motor #2 to ground.
Old Aug 16, 2014 | 03:05 PM
How would I do a continuity check? I have a multimeter but don't really know how to use it. Thanks.
Old Aug 16, 2014 | 03:48 PM
Aaron0313's Avatar
Some meters have a specific continuity setting which beeps when there's 0 ohms resistance between the two leads. Otherwise just use the resistance setting and see if you get 0 Ohms between the black wire off of fan 2 and a ground point of the vehicle.
Scott 05
Mar 17, 2014 07:31 PM
Leprechaun93
Dec 16, 2013 06:57 PM
Steven73
Nov 15, 2009 04:45 PM
BeachBumMike
Sep 29, 2006 01:47 AM
montejass
Jul 7, 2006 10:39 AM
