6th Gen ('00-'05): Need help
Old Apr 9, 2019 | 07:49 PM
Jamestreash's Avatar
Default Need help
I have a 2004 Monte ls 3.4 and it vibrates when turning right and when accelerating. Already changed driver side axle and it still does it. I noticed the output shaft moves around inside the seal. Is that normal? And does the seal (if its good) hold it centered and keep the axle from vibrating?
Old Apr 10, 2019 | 03:15 PM
nitehawkjcb's Avatar
Might be the wheel bearing/hub.
Old Apr 10, 2019 | 03:22 PM
I thought about that, driver side was changed about 2 years ago and passenger side last year. My next move will be the output shaft seals on both sides. Both output shafts have enough play in them that I can move the axles slightly. I wonder if those seals are supposed to keep the output shafts centered?
Old Apr 13, 2019 | 12:42 AM
I think the seal just keeps transmission fluid from going everywhere.
Old Apr 14, 2019 | 11:57 PM
O-Five's Avatar
delete
Old May 14, 2019 | 06:20 AM
Pg1248's Avatar
I thought the unloaded axle, is the noisy one? I. E. Less torque, more noise? Also, the seal doesn't center the axle. There's a sleeve bearing in the transmission.
Monsta _ carlo07
Apr 20, 2017 07:59 AM
gtr25
Mar 16, 2016 10:26 PM
jt_lefebvre
Mar 30, 2015 11:48 AM
racerjim0
Nov 10, 2014 06:47 AM
Monte_Man04
Dec 26, 2013 01:02 PM
