Opinion Needed: My z34 SS idles too high upon ignition. What could be the cause of this and what is
Old Jun 5, 2019 | 09:23 AM
Bj Lewis Culbertson's Avatar
Default My z34 SS idles too high upon ignition. What could be the cause of this and what is
I have a 95 z34 SS, and when I'm accelerating into about 3rd gear (3 RPM) my tranny starts acting like I just shifted into neutral! What is the cause of this and what can I do to fix this?
Old Jun 5, 2019 | 11:25 AM
volkerc's Avatar
how many miles on the tranny?
Old Jun 5, 2019 | 11:35 AM
120,000
Old Jun 5, 2019 | 01:54 PM
volkerc's Avatar
what exactly happens from idle to 3000 and after?
Old Jun 6, 2019 | 08:24 AM
nitehawkjcb's Avatar
Hopefully it's a vacuum issue, I think the 95's had a vacuum modulator on the transmission (I could be wrong though). Otherwise, check the transmission fluid level... If the fluid is OK then it likely needs a rebuild.
Old Jun 6, 2019 | 09:44 AM
the Car may only need a Transmission fluid and filter change check the fluid and see what it looks like.
Make sure you have serviced the Trans and it might only need a fluid change.
Old Jun 6, 2019 | 12:03 PM
At ignition, car starts off idling almost 2 rpm and slows down. When put into drive and accelerating, if you barely press the gas pedal, it will shift fine, but if you step on it , it will run the rpm's past 4 like it's on neutral
Old Jun 6, 2019 | 12:25 PM
https://www.google.com/search?q=yout...&bih=786&dpr=1
Check this link for more information.
Bj Lewis Culbertson
Jun 5, 2019 09:21 AM
bluecar
Aug 16, 2017 09:21 PM
urbanyi1
Jan 3, 2011 04:43 PM
MVP4350
Dec 4, 2008 09:27 PM
vegav6
Apr 14, 2007 09:00 PM
