My z34 SS idles too high upon ignition. What could be the cause of this and what is
I have a 95 z34 SS, and when I'm accelerating into about 3rd gear (3 RPM) my tranny starts acting like I just shifted into neutral! What is the cause of this and what can I do to fix this?
how many miles on the tranny?
Originally Posted by volkerc
(Post 717725)
what exactly happens from idle to 3000 and after?
Hopefully it's a vacuum issue, I think the 95's had a vacuum modulator on the transmission (I could be wrong though). Otherwise, check the transmission fluid level... If the fluid is OK then it likely needs a rebuild.
the Car may only need a Transmission fluid and filter change check the fluid and see what it looks like.
https://cimg2.ibsrv.net/gimg/monteca...26f308b074.jpg Make sure you have serviced the Trans and it might only need a fluid change. |
(Post 717731)
