MY Monte Carlo wont start/crank
Over the last couple of weeks my car just doesnt start, you turn the key you get nothing but power. I have checked the battery it is good, new distributor, and new starter all correctly hooked up still nothing. What else could i check and see what the problem is? I have taken the cables off and cleaned them and made sure no rust on battery cables and still nothing. Every know and then the car will turn over and start no problem, but you can drive it for a little bit turn it off and start right back up or more often than not it doesnt start back up. I dont know what else to check, it is a 95 Z34 3.4L What else could i check at home before i have to pay more money to get it towed and check at a mechanic shop?
The check engine light comes and and then you go to Autozone or AAMCO and get a free computer check up.
(if your car was running)
Otherwise you have to have someone come to your house with a scanner or tow it to a mechanic to have someone plug in a scanner to your car.
It's probably your VATS. Does the security light stay on?
Anyway, you could buy a new ignition switch and keys, or bypass the VATS (Vehicle Anti-Theft System).
Here's a walkthrough:
http://vats.likeabigdog.com/
I have a 2000 Monte Carlo ls I went to crank it up it tried but my battery was dying like all ways so I charged my battery up and there where no sound lights came as all way I did the 10 min thing nothing happen nutrual thing didn't work either starter brand new battery brand new alternater good 100% so wats wrong pls I need help ASAP job on the line and kids school
