Multiple problems could use help
yes it can, other symptoms of a bad cat are:
Tachometer
Decreased engine power--indicated by low revolutions per minute (RPMs) on the tachometer--is a symptom of a bad catalytic converter.
Acceleration
Another sign of decreased engine power is hesitating or bucking when you try to accelerate.
Driving Uphill
The car may seem to lose some power when going uphill.
Temperature
If the engine runs hotter than usual but the cooling system is up to par, that may indicate catalytic converter problems.
Exhaust
Black smoke coming from the exhaust pipe may be a symptom of a bad catalytic converter.
Smell
A failing catalytic converter can cause a rich fuel mixture that makes the exhaust smell like rotten eggs from the hydrogen sulfide.
Tachometer
Acceleration
Driving Uphill
Temperature
Exhaust
Smell
Habbibie
Jun 24, 2015 04:58 PM
5th Gen ('95-'99): 1999 Model - ABS Light is on. Could use some help with diagnosis.
MCarlo99
Aug 19, 2012 03:57 PM
pizzacarlo
Nov 1, 2010 08:36 PM
speedySS18
Oct 24, 2010 05:19 PM
