Monte on my nerves.
Old Jul 12, 2016 | 02:54 PM
mrmad40's Avatar
Default Wont Start
Ok just recently I had a problem with hesitation with my 2003 Monte Carlo 3.8 Cleaned Maf and Throttle body... Today it died on the free-way now it will not stay running at all. Had to have it towed to my house. Any ideas????? Much help appreciated. Thanks
Old Jul 13, 2016 | 05:10 AM
montedd's Avatar
Was it running rough before you cleaned theMAF? Any codes? Any symptoms leading up to the current state?
Old Jul 13, 2016 | 08:51 PM
mrmad40's Avatar
Cleaned the maf and throttle body 2 weeks ago. It has had a hesitation problem that started at that time. Its not throwing any codes. Today went out and it started but my rpm"s are going from 700 to 1100 up and down when idle's.
Old Jul 13, 2016 | 08:57 PM
What is the mileage and when was the last time plugs/wires were changed?
Old Jul 13, 2016 | 09:07 PM
mrmad40's Avatar
The engine is not the original this engine has about 85k on it. The owner a a stealership is who I bought it from . I have not changed the plugs or wires yet.
Old Jul 15, 2016 | 10:28 AM
I'd check clean the IAC..
I also recommend changing out the MAF..
be sure it's an ac delco...DO NOT USE AN AFTER MARKET BRAND!
Old Jul 15, 2016 | 05:56 PM
mkenney's Avatar
I had a stalling problem on my '02 and it turned out to be the cam shaft sensor.
Old Jul 15, 2016 | 08:49 PM
mrmad40's Avatar
Thanks for your help guys.
Old Jul 16, 2016 | 07:30 PM
mrmad40's Avatar
Default Monte on my nerves.
Posted a few days ago about my 2003 monte 3.8 won't stay running changed out the ICM no change. Thinking it maybe Crank shaft sensor????? I start it cold runs a few minutes then the RPM"s go up and down then it dies. Then won't start. Errrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr LOL Any more ideas?????
Old Jul 16, 2016 | 08:54 PM
shawn parker's Avatar
I'll give you a bump so more knowledgeable members might respond
