Opinion Needed: Monte Carlo SS want start
Old Jul 25, 2016 | 10:05 PM
antoinettegrant30@yahoo.com's Avatar
Wink Monte Carlo SS want start
I have a 2002 Monte Carlo SS that will not start. I have replaced the crank shaft sensor, camshaft sensor, ignition switch, cylinder, pass lock sensor, and control module with brand new coil packs. It will crank but it want start. Assistance is welcome.
Last edited by antoinettegrant30@yahoo.com; Jul 25, 2016 at 10:07 PM. Reason: Mispelled
Old Jul 25, 2016 | 10:27 PM
turbo monte's Avatar
is the security light on? can you hear the fuel pump prime when you cycle the key?
Old Jul 26, 2016 | 06:45 AM
No the security light is not on. I hear the fuel pump prime when I cycling the key
Old Jul 26, 2016 | 08:39 AM
No the security light is not on. I hear the fuel pump prime when I cycle the key
Old Jul 26, 2016 | 08:25 PM
Well first thing to do is make sure you have spark to every cylinder and next is make sure you have good fuel pressure. If all that checks out then run a compression test on the cylinders
Old Jul 26, 2016 | 08:53 PM
plumbob's Avatar
Have you scanned for codes?
Was any work done just prior to the problem?
