monte carlo ss 2003 radio wiring diagram (amp)
Old Sep 19, 2015 | 03:50 PM
Kenny Guido Temprano's Avatar
Default monte carlo ss 2003 radio wiring diagram (amp)
ok, I finally went out and got me an aftermarket radio. i already had pioneer 6x9s i threw in there. i got myself a kenwood deck with gps, dvd player...all the bells and whistles. you guys told me that i would have to get a kit to get it working with the electronics that are in the radio because you said some of the components may not work. well, after it was installed, the speaks sounded like crap, and they kept cutting out. so i started replacing all the speakers and i wanted to disconnect the factory amp. well, i hacked it up pretty bad. sounds like **** and i dont have a diagram of what went where. is the factory amp a passive or power amp? im assuming its a 5 channel amp, correct? someone please help!
Old Sep 19, 2015 | 05:11 PM
Budsjlm's Avatar
I bypassed my factory amp splicing in an after art one, if you want to run a aftermarket amp easiest for you would be to just run the rca's from the head unit, I used the factory head unit so that wasn't an option give me a few minutes and I'll post the pic I went off of
Old Sep 19, 2015 | 05:45 PM
Budsjlm's Avatar
Take a look at this, looks like earlier year's like mine are different but here's what should work for ya bbenginerings post
I DID IT!!! AMP BYPASS!!! - Forums - NAIOA
Old Sep 19, 2015 | 06:44 PM
For now, i just want to eliminate the amp all together. i want to use the radio to power the 4 speakers but i dont know which wires go to the out of the radio.
Old Sep 19, 2015 | 06:58 PM
thank you!!!!
