7th Gen ('06-'07): Monte Carlo PRND LIGHT WILL NOT TURN OFF WHEN CAR IS SHUT OFF
Old May 12, 2021 | 06:22 PM
Rondelle15's Avatar
Default Monte Carlo PRND LIGHT WILL NOT TURN OFF WHEN CAR IS SHUT OFF
My 2007 LS MONTE CARLO keeps dying everytime it’s sits for a couple of hours when I turn it off the only light that stays on when I turn my car off is my dash but it’s not my entire dash it’s the PRND light and I am not sure where to start PLEASE HELP !!
Old May 12, 2021 | 08:47 PM
Barovelli's Avatar
Electrical gremlins were the bane of my Monte. See if pulling the RAP fuse makes any difference. RAP or retained accessory power is the circuit that powers things with the key out of the ignition.
Fuse is in the passenger side kick panel fuse block.
Old May 14, 2021 | 06:45 AM
Rondelle15's Avatar
Hey thanks for the help I pulled the RAP fuse that and it’s still not turning off
Old May 14, 2021 | 09:04 PM
Barovelli's Avatar
OK. On to more troubleshooting. Check the relays in the fuse box under the hood. Pull one out, check your dash. See if one is stuck or bad. Do the same for all relays.
Then I'd move on to fuses. Pull one at a time and see if that shuts off the lights. Won't fix the issue but it might pinpoint the circuit.
After that, I'm out of ideas. Light switch maybe?
Just the P R N D 3 2 1 and not the Odometer/Compass/temp/other DIC display? Old picture for reference.
bettare
Jul 4, 2015 09:01 AM
Aborolus
Mar 12, 2014 11:35 PM
Jlewis229
Jan 26, 2012 04:02 PM
NovaSS369
Jul 2, 2011 12:58 PM
thomas82363
Dec 1, 2010 09:45 AM
