monte carlo 2000 3.8 v6
Old Mar 13, 2014 | 03:22 PM
angies.3811@gmail.com's Avatar
Default monte carlo 2000 3.8 v6
boot on transaxel throwing grease out on right side 3.8 v6 2000
Old Mar 13, 2014 | 03:30 PM
nitehawkjcb's Avatar
Replace the boot or the axle...
Old Mar 13, 2014 | 10:43 PM
owens91's Avatar
Bam problem solved lol
Old Mar 14, 2014 | 11:51 PM
Viperpit's Avatar
if you let it go too long it will start to vibrate if its the one closer to the case. if its the outter one..... go to a parking lot and lock the wheel over fully to the right and drive in a circle, listen for a clacking sound. do the same with the wheel locked to left too.
if you get a clacking sound, your CV joint is bad too and the entire axle assy must be changed.
billyp35
Feb 1, 2007 08:00 PM
TGAbreu
Dec 9, 2006 10:31 PM
Mike
Aug 29, 2006 10:33 PM
00pacecar
Jul 6, 2006 02:18 AM
te100
Jan 29, 2006 05:31 PM
