6th Gen ('00-'05): Monte Carlo 03 ss parasitic drain clus/BCM /data link connector fuse draining battery
Old Sep 13, 2018 | 01:24 PM
Cameron Sittig's Avatar
Default Monte Carlo 03 ss parasitic drain clus/BCM /data link connector fuse draining battery
Clus/BCM/ data link connector fuse draining battery while engine not running voltage reading is 02.9 I don't know where to go from here
Old Sep 13, 2018 | 01:47 PM
Default Parasitic drain 03 Monte Carlo ss
Mc battery is dead if fuse that reads cluster BCM data link battery is not removed anybody know what would be causing this?
Old Sep 27, 2018 | 01:50 PM
Brett's Avatar
I had the same parasitic drain issue with my 2005 LT. What I did was cleaned my battery cables and replaced the battery rundown protection relay ( located on my LT in the passenger side fuse block ). Idk if it was just a loose/corroded batty cable or relay but after I done that I haven’t anymore battery drains. Hope this helps.
Joe Reber Sr.
Sep 16, 2018 07:40 PM
Zack Davis
Sep 24, 2017 09:28 AM
plokm24
Jul 26, 2016 02:51 PM
RonBGA
Nov 20, 2012 09:14 AM
bubba
Apr 26, 2010 09:48 PM
