Monte Carlo 03 ss parasitic drain clus/BCM /data link connector fuse draining battery
Parasitic drain 03 Monte Carlo ss
Mc battery is dead if fuse that reads cluster BCM data link battery is not removed anybody know what would be causing this?
I had the same parasitic drain issue with my 2005 LT. What I did was cleaned my battery cables and replaced the battery rundown protection relay ( located on my LT in the passenger side fuse block ). Idk if it was just a loose/corroded batty cable or relay but after I done that I haven’t anymore battery drains. Hope this helps. |
