Lubricating ignition key slot: bad idea?
Old Dec 29, 2015 | 05:10 PM
Sidestreet's Avatar
Default Lubricating ignition key slot: bad idea?
I'm toying with the idea of adding a drop or two of 3-in-1 oil to my Monte's ignition key to help it move into (and out of) the slot more easily and quickly. It always goes in and works, but it just feels rather tight and slower to push in and pull out than what I'm used to with other cars.
Might the lubricating oil interfere with the little black PASS-Key resistor pellet on the key, and/or its matching sensor inside the cylinder? Or could something else go wrong by introducing some oil? Maybe there's a better lubricant to use for this? Otherwise, the key and the cylinder is working just fine.
Old Dec 29, 2015 | 06:03 PM
I would not use an oil based product to lube the ignition, it could change the resistance and possibly trip the pass lock system. My mechanic uses the dry graphite on ignition switches and oil based on car door / trunk keyed entry locks.
Old Jan 1, 2016 | 09:03 AM
Sidestreet's Avatar
Thanks Zippy, a little dry graphite is probably what I'll use when I get around to it. Just wondering though, would a little WD-40 work as well? I heard a while back from an old mechanic that it's electrically conductive, though I don't know if that would be a good or bad thing in this case.
Old Jan 1, 2016 | 01:52 PM
jason2982's Avatar
I would go with the dry graphite suggested as WD-40 isn't a long term lubricant. You would be back to the same issue in a weeks time or less.
