low tire pressure message
i was driving my new used o3 monte ss into town last night when the low tire pressure warning came on in the message center in the guage cluster,i stopped at a service station and checked the pressure and put air in tires as needed,i then drove on but the message did not go off.i know the pressures are right in the tires(33psi).am i going to have to take this car some where to get hooked up to computer to get the message off or will it eventually go out on its own.thanx,christy.
There's a sticky in the "how to" sub-forum on that subject. It's REAL easy. You turn the ignition to on and click your heels together three times and..........
Really, it's over there and I'd tell you here, but you NEED to check out some of those stickys yourself, as they are GREAT.
Now you can drive like the wind, straining the limits of machine and man.
montejass
FWD Tech Guides '95-'07
42
Sep 22, 2021 10:19 AM
6th Gen ('00-'05): Low Tire Pressure Message does not go away
MonteCarloSS02
Aug 29, 2014 08:46 AM
