Low fuel pressure
Old May 20, 2015 | 02:31 PM
moore47's Avatar
Default Low fuel pressure
Hi all, Hope you can help with a problem I've been fighting for a while. I get a random rough idle and stall in my 97 Z34. Thought it was an issue with the spark and proceeded to replace coils, plugs, etc.... Replaced fuel filter about 3 months ago. I get 30 psi fuel pressure reading with ignition on. Drops to low 20's at start and stays at 30 psi during idle. Drops down to 22 psi under high revs. Manual says I should be around 40-31 psi at idle and 40ish at ignition. What would cause low fuel pressure? I though fuel pumps are all or nothing. is there anything else that could cause low fuel pressure? Sure do not want to drop the tank and install a new pump.
Old Jul 3, 2015 | 11:04 PM
child_of_fire's Avatar
my guess would be fuel pressure regulator (cheap fix worth trying) or the fuel pump itself....
joe111599
Jun 10, 2016 07:01 PM
robknight13607
Mar 20, 2013 09:14 AM
Randy Biron
Jul 14, 2012 08:07 PM
big green dog
Mar 14, 2012 02:56 PM
keghead40
Jul 19, 2005 12:13 AM
