6th Gen ('00-'05): Low Coolant Light comes on for 5-10 sec at start.
Old Nov 11, 2016 | 10:52 AM
mkenney's Avatar
Default Low Coolant Light comes on for 5-10 sec at start.
My low coolant light comes on at ignition, then turns off a few seconds later. The level is fine and it doesn't run hot. The sensor is a few months old as well as the ignition switch. Any ideas? Is this a common problem?
Old Nov 11, 2016 | 12:56 PM
WBody's Avatar
Sensor is for sure good? Good connection sending receiving data/wires ok? Proper level of coolant within system/bleed properly and fully?
