Low coolant.
Took the monte in today to have it looked at at my local shop. He said he thinks it is just the dex-cool which he said will do that. Hmmm. Never heard that before. He wants to give it a good flush and he thinks that will do it. I had already cleaned the sludge around the cap and neck so he didn't see that although there was still some there. Think I will look for a second opinion.
Yes DEX COOL will do that seen it myself as well.
If possible get rid of DEX COOL all together I went with a premium antifreeze in my 04 Impala
I have also heard of the dealers adding some additive to some of these cars that were having the coolant leak issues probably something like BARS LEAK. This was considered OK and not just a band aid either.
Not sure if you owned yours since new as maybe someone put some additive into the coolant.
DexCool Sludge; Cleaning | Cooling System Fluids & Additives | Bob Is The Oil Guy
My low coolant light kept coming on and I found where it was leaking from by running the engine for a few minutes and watching it as it ran. It was coming from a small elbow hose connected to the water pump. Went to O'Reilly's and one of the employees told me it happens often because their plastic. You can get aluminum ones for cheap and it's an easy fix. My 02 SS has been running smooth and blowing out HOT air since. Hope this might help others
I think you mean the coolant elbows connected to the belt tensioner. Ya, that is a common one. Glad to hear you got good advice on replacing them with the aluminum ones, and it was the easier fix. Congratulations on a successful repair.
