Low beams not functioning
Old May 15, 2014 | 12:31 PM
Crusader SS's Avatar
Originally Posted by 03SSLE
Have you checked the fuses?
Underhood Upper fuse panel:
DRL/EXIT LTS
EXIT LTS
If you used a harness to tap power directly from the battery there is most likely an inline fuse in it also.
Hey Mike. I did see those fuses, do they also control the low beams? The labelling threw me. Thanks for the help,
Old May 15, 2014 | 12:33 PM
Hiroska's Avatar
Mine under the hood is indicated LT low, RT low.
Old May 15, 2014 | 12:38 PM
Thanks. I think the 7th gens are a little different. I don't see the same labeling on my fuse box.
Old May 15, 2014 | 12:41 PM
dbaldwin's Avatar
Damien, I assumed you plug the stock bulbs back into the stock plug locations right? Anyways. If the fuses are good then the Relay is the next thing to check, I believe all the relays are the same so you can swap it with the one next to it to check it. I'm not 100% sure on that part but it should be correct.
Old May 15, 2014 | 12:53 PM
03SSLE's Avatar
The DRL/EXIT LTS are the upper/lower left (driver) and the EXIT LTS is for the upper/lower right (pass) side lights.
Old May 15, 2014 | 01:19 PM
Well, I checked the DRL and exit fuses and they both look good. I have included pics of my engine bay and drivers side fuse boxes.
File Type: jpg
Old May 15, 2014 | 01:22 PM
Here is the engine bay fuse boxes. For some reason, my iPhone won't let me attach more than 1 pic at a time.
File Type: jpg
Old Jul 30, 2014 | 12:49 PM
WendyCGP's Avatar
Default Headlamp relay
how do you get the second cover open inside the car drivers side fuses
I need to change the headlights relay?
Wendy
Old Jul 30, 2014 | 01:59 PM
WendyCGP's Avatar
healight Relay "Replacement." 2001 chevy monte carlo ss
Old Jul 31, 2014 | 06:39 AM
WendyCGP's Avatar
How do you open the second cover?
svzpt71
May 11, 2015 06:30 PM
NovaSS369
Jul 2, 2011 12:58 PM
montecarlo48178
Oct 9, 2010 03:31 PM
KWJR86
Apr 21, 2010 08:27 AM
mickey
Mar 20, 2008 06:15 PM
