looking for power
Hi there and welcome to the forum!!
This link should help get you started -->https://montecarloforum.com/forum/fw...n-3800s-10942/
Don't touch the crank if you do the build. Just mess with the cam.
yes,ive heard the bottom end is plenty strong enough to handle just about whatever you throw at it unless you do a wild setup,i was kind of sketchy on going the turbo route but il be going with the z7 turbo kit from zzp,il let you know how that goes
but if you just want a NA setup you can go with a XP HOT cam from zzp,thats the cam that I plan to use
if you want a nice sounding cam on a N/A 3800 get the NIC cam. i also agree turbo is the only way to go for big power gains. this is the route i went from day one on my build and love it. now remember these transmissions in these cars are garbage, if your planning to make big power plan to have dave at triple edge building you a performance transmission as well.
Come on and make the leap to a turbo system, then you get to smile when the build is complete...
easiest thing to do is call dave and talk with him. he will ask your hp goals and then set you up with a good trans and give you a price!
