lighting on defrost heater control
Old Apr 28, 2010 | 10:17 PM
roughroc's Avatar
Default lighting on defrost heater control
I just purchased a 04 MC and noticed the lighting around the switch that controls the different options for vents does not light up. Also no lighting on the heat-cool slider gague. Lighting does work around the fan control ****. Was wondering if this is normal or should there be LCD lighting on these parts.
thanks
Old Apr 28, 2010 | 10:28 PM
Have you checked the fuse for it yet, or does that fuse control other things that are working fine now? I know like if your cruise control fuse is blown, you wont have a light on there. ???
Old Apr 28, 2010 | 10:52 PM
Enzo354's Avatar
STILL SLOW
Your bulbs are probably burnt out like mine.
Check out
http://www.bbengineer.com/cars/impala/store.htm
Old Apr 29, 2010 | 11:43 AM
roughroc's Avatar
thanks for the responses.
I guess it looks like a person needs to look for a used one and hope the lighting and everything else works. The link is good to have it rebuilt, just trying to figure if i want to go without a unit for a couple of weeks. Good to know there is alternatives out there besides dealer. Have a weird one with the blinkers. Couldnt figure out why they wouldnt work. turns out the hazzard was unpluged and they wount work with out it pluged in from the back. Took a dealer at 120 an hour to figure it out. Found a multi switch for 385 not 550 from the dealer which helped when the high beam switch wouldnt work.
this is a good forum, glad people will help.
Old Apr 29, 2010 | 11:59 AM
Yeah, the dealership won't even fix the burnt out bulbs either. They consider it an "unserviceable" item.
There are ways that you can do it yourself, if you are good with opening up electronics and soldering.
If you check moradpartscompany.com sometimes you can find one for sale. Just be careful, as they are different in some models. For example you probably have a lot of dots to represent the fan speeds, where I have 1,2,3,4,5.
Lalozx
May 19, 2015 08:20 AM
seawolf18
Apr 3, 2012 10:49 AM
depends187
Jul 8, 2010 02:29 AM
rhythym7
Dec 27, 2008 08:58 AM
jcoeracing97
Aug 8, 2006 07:34 PM
