Landau Top Removal
Old Aug 11, 2006 | 07:41 PM
monte83's Avatar
Default Landau Top Removal
Does anybody know how the rear quarter window trim fits after removal of the landau (vinyl) top. Can I reuse the existing trim or will it fit incorrectly due to the extra thickness of the top?
Old Aug 15, 2006 | 06:04 PM
mickey's Avatar
Default RE: Landau Top Removal
should fit the same on that year as with it . they top should not actually go under the drip rail or the 1/4 trim it should only but up to it.
But taking those tops off is nto afun job. they are glued in to place and also have the rivets acrossed the top of the car to hold on the trim so wyou will need to pull the top off then grin those down and fill it in to mak eit smooth agian.
but the trim on cars with or with out should be the same for around the windows.
Good luck
Old Aug 15, 2006 | 11:31 PM
monte83's Avatar
By the way, it is an 83
Old Aug 16, 2006 | 07:26 AM
mickey's Avatar
yeah then they should be the same for trim with or with out the top on it
other then the one acrossed the top of the car that one is only there for the cars with the tops that i have seen
But if you can handel the body work dont worry about it they are not hard to remove those are only spot welded on . and break off easily. just becarfule not to bend the metal on the car doing it. I would sujest a dremel tool to cut them off as close as you can then grind the rest down and make it smooth
etvalentin
Dec 14, 2012 08:16 PM
74Landau
Aug 23, 2009 07:53 PM
RocknSS04
Apr 21, 2009 08:43 PM
79Monte
Jan 29, 2007 06:44 PM
warrantykiller04
Jun 20, 2006 11:23 PM
