l67 idler pulley question....
Old Jan 26, 2014 | 10:03 AM
vikesfan's Avatar
Originally Posted by l67ss
Lil pro tip i learned on my buddies gtp, use an extra #3 pulley(tensioner on alternater) and use it instead of the #8 pulley. Theyre the same size and offset. The tensioner pulley is steel. The stock #8 isplastic and likes to shred itself when it tries to sieze. Metal one is also friendlier to the sc belt than the plastic
yep, already done
the parts store actually has the metal one listed as the direct replacement, not sure if its the same part number as the #3.
Phone wouldnt let mepost a pic. Look in my albums, i DID upload some pics there of it. You did change the oil filter adapter didnt ya ?
i ended up finding the bracket mixed in with some of the other parts so i am good to go now.
and why would i need to changed the adapter? they were exactly the same? remember i am using the 2008 L26 N/A 3800 block.
Old Jan 26, 2014 | 04:58 PM
l67ss's Avatar
Youre using n h-body 3.8 right? If so you need a w-body oil filter bracket. If not disregard
Old Jan 26, 2014 | 06:01 PM
vikesfan's Avatar
the block came out of a 2008 grand prix and has the exact same filter adapter as my 2002.
i am only using the heads, intake, supercharger, pulleys, brackets, etc... from the Buick Ultra
Old Jan 26, 2014 | 11:00 PM
l67ss's Avatar
K disregard previous post then
tlip06
Mar 19, 2008 10:34 PM
tlip06
Feb 24, 2008 10:34 AM
RocknSS04
Sep 8, 2007 04:16 PM
Whit804
May 3, 2007 11:02 PM
87monte
Jan 16, 2007 05:00 AM
