L67 Fuel Injectors
Old Aug 24, 2011 | 10:07 PM
oneslowmonte's Avatar
Default L67 Fuel Injectors
Well, I bought six fuel injectors from a questionable source recently for the top swap that I hope to do before Christmas, but anyways after testing them they all came out to between 14.8-15.0 ohms, I was wondering if that was within the normal range of resistance. I was unable to find it online, and was a little worried that the injectors I bought weren't any good. Thanks for any and all input and guidance!
Old Aug 25, 2011 | 04:02 AM
Wilco's Avatar
The 3800 engine uses high-impedance 12 ohm injectors, and the test spec is 11.80 to 12.60 ohms.
Old Aug 25, 2011 | 08:12 AM
Oh man, looks like I will have to buy new ones. That is a bummer, I was excited because they were consistent but then I was like wait, 14.8-15.0 seems a bit high.
Old Aug 25, 2011 | 08:33 AM
zipper's Avatar
Can you post a pic of the injectors? You can tell if they're L67 injectors by looking at them.
Old Aug 25, 2011 | 08:42 AM
Well, I'm starting to feel really stupid. Here they are.
Old Aug 25, 2011 | 08:58 AM
zipper's Avatar
Okay, here's the deal on those injectors. They came from a Series I L67, not a Series II L67. IIRC, they're 28# injectors (vs 33# for S2 L67's).
Series II L67 injectors look like this:
Old Aug 25, 2011 | 09:02 AM
Oh boy, can I still use the fuel rail or cylinder heads from a series 1?
Old Aug 25, 2011 | 09:12 AM
zipper's Avatar
Don't go that route. The injectors are the cheapest part of the setup and for a top swapped L36 the smallest injectors you will want will be 33# injectors. I've seen S2 L67 injectors go for $35/shipped on clubgp before and at most $50/shipped. Just buy another set. Also, ZZP buys back L67 injectors for $10/each. You could contact them to see if they would buy your S1 L67 injectors. The worst they will say is no.
Old Aug 25, 2011 | 09:15 AM
Unfortunately I think I already have the S1 heads and rail so I was just wondering if they would work or if I would have to scrap them. Man, this sucks. There is a poster on Craigslist with a decent deal I'll have to look into I guess. I just wasn't sure if the rail or heads were the same from S1 to S2.
Old Aug 25, 2011 | 09:48 AM
zipper's Avatar
Can you post a pic of the heads and rail? I don't think they will work though.
