key remote fob
Old Jun 12, 2014 | 11:18 PM
99-03SS-07SS's Avatar
Default key remote fob
In my 07 ss black car, I could unlock and remote start in good distance.
When I traded in for another 07 as blue car, and I only can unlock this car about 1 car away.
Why?
What's the point of having remote starter if u can't start car in far distance.. :-(
Tks
Old Jun 13, 2014 | 08:23 AM
VictoryRedSled's Avatar
transmitter or battery in current fob are on the way out...try getting a new fob battery first and see if that helps, if it doesnt, id just get a new fob and reprogram it to your car.
*also can a mod move this to the appropriate forum please*
Old Jun 13, 2014 | 08:39 AM
03SSLE's Avatar
GM had problems with the remote start in Monte Carlo and Impala models from '06 forward. This problem can be resolved under warranty (if applicable). The dealer needs to replace the receiver, add an antenna booster and replace the key fobs.
Old Jul 11, 2014 | 09:39 AM
I'm aware of battery, thank you and its not the issue.
Old Jul 11, 2014 | 10:08 AM
Ok thanks. I'll let dealer know...
Also I read some comment from someone when I googled the problem. He said that air psi sensor is also part of this issue. My driver side front tire sensor do lose info from that tire, showing blank in display once a while. I want to double check to see if this is actually related issue.
Old Aug 8, 2014 | 12:47 PM
Ok.. Service said warranty and extended warranty wouldn't cover it. And I have to buy extended range antenna. He suggested me to buy aftermarket since it cost $400..
I hate aftermarket bec they always last a year or less..
Do u have any recommendation on good aftermarket?
Old Aug 8, 2014 | 01:03 PM
GM had a TSB about it, but never an actual recall on it
Agreed, it's so expensive for remote start to work the way it is meant to. It was such a shame on those cars.
You can probably try to find the TSB and maybe it lists parts and DIY, and just use the dealer to program?
Old Dec 6, 2014 | 11:22 AM
NewJersey Art's Avatar
TSB# 07-08-52-001C
Remote starter issues see above
Old Dec 7, 2014 | 03:26 PM
jim1405's Avatar
Mine 2007 quit working and the receiver and key fobs were replaced under warranty. The original had good range but the replacement is a lot shorter. Yours may be working properly though, I have seen a handful of posts elsewhere that other peoples replacements also were not as good as the original.
Habbibie
Mar 10, 2012 12:58 AM
Sbrunelli
Oct 18, 2010 11:16 PM
ralphtrent
Dec 24, 2005 01:01 PM
03SSdriver
Sep 16, 2005 10:43 AM
