just got a monte carlo ss 2007 and having issues
Old Mar 17, 2012 | 12:46 AM
most-hated's Avatar
Default just got a monte carlo ss 2007 and having issues
when i turn on the car in the cluster it tells me the hood is open but its not what can it be did the sensor go bad ? is there a way to rig it ?
another thing the cluster also says something about watch for ice on road and service traction control
Old Mar 17, 2012 | 07:45 AM
Welcome to the Fourm. Athough I do not know the answer to your problem I am sure someone from the Fourm will have an Idea
Old Mar 17, 2012 | 10:28 AM
most-hated's Avatar
thnx and i hope so cuz its frustrating lol
Old Mar 17, 2012 | 10:31 AM
I don't know about the hood open sensor, I would check the linkage?
What is the weather like by you? If it is cold your warning message will tell you to watch for ICE. Does the car tell you the temperature? You might have that sensor gone too.
Service traction control could be a wheel hub assembly.
Old Mar 17, 2012 | 10:59 AM
Jester_20's Avatar
i'd just pop the hood and play with the sensor to see if i could get the light to go off and kinda judge the problem from there . . . whether it needs adjusting or replacing
Old Mar 17, 2012 | 05:00 PM
most-hated's Avatar
its 80 some degrees out lol the temp on my dash reads -40 so somethings got to be wrong do u know the location of that sensor
how would i check the wheel hubs to see which one it is ?
i already did that and nothing the sensors cost 100 and some at the dealer but was wondering if there's a way if i could unplug it and rig it to think that its closed all the time so my remote start can work
Old Mar 17, 2012 | 05:23 PM
The Ambient Air Sensor should be near the radiator, this link should help:
W SENSOR/TEMPERATURE OUTSIDE AMBIENT;. Fits: Impala, Monte Carlo | Nalley Buick GMC Brunswick
It's a $4 part from Rock Auto
There is no easy way to know which hub unless it is pretty bad, could just be a wiring issue to the hub also. Do you have an ABS light as well? That ABS light should throw an ABS Code to the hub.
Old Mar 17, 2012 | 05:50 PM
most-hated's Avatar
yes the abs light is on
Old Mar 18, 2012 | 10:51 PM
most-hated's Avatar
ttt...
Old Mar 18, 2012 | 10:53 PM
Originally Posted by most-hated
ttt...
what's the bump for? Chibi basically told you everything that you need to know unless you have another question?
