Impossible Headlight Issue !! Help
Old 02-28-2016 | 07:34 PM
plumbob's Avatar
More food for thought in troubleshooting the DRL circuit. Here are two videos, parts 1&2 where the problem was a diode noted in the end of part 1 and beginning of part 2.
Part 1:
Part2:
  #32
Old 02-28-2016 | 07:51 PM
Alex S's Avatar
Part 1:Daytime running light circuit troubleshooting (DRL circuit) - YouTube
Part2: Part-2 Daytime running light circuit troubleshooting (DRL circuit) - YouTube
Ooo. Very helpful. now I shall try and find this diode on the Monte. Wouldn't happen to know where it's located ? 😬
  #33
Old 02-28-2016 | 08:03 PM
plumbob's Avatar
Not off the top of my head. Give me some time to look in the factory service manual. Maybe another member can chime in here that knows?
  #34
Old 03-01-2016 | 06:20 PM
Alex S's Avatar
Any luck on finding that diode by chance ? I've watched those videos. And I might try and pick up a test light to give it a shot. Move also looked for the diode. But no luck. Doesn't seem to be anything under there resembling the one in the video.
  #35
Old 03-01-2016 | 09:56 PM
plumbob's Avatar
Okay, so here's what I found; good news and bad news.
First the bad news: I searched the factory manual in schematics, component locator views, and the index and could not find anything like it. Apparently our cars don't have one. Sorry if I sent you on a wild goose chase.
Now for the good news: I found a lot of information on the headlight circuit description, how it works in conjunction with the BCM and a troubleshooting guide. See attached pages from the factory service manual.
Now I have to ask, have you had the car scanned for codes? Most lighting system component failures will trigger a DTC that starts with a B.
Hope this helps, Curt
*The attachments were too large to all fit in one post. See next for circuit desriptions.
File Type: jpg
  #36
Old 03-01-2016 | 09:58 PM
plumbob's Avatar
Headlight / DRL circuit description:
  #37
Old 03-02-2016 | 08:19 PM
Alex S's Avatar
I have not taken it to a shop to have it scanned. But the check engine light is off. And I have my own scanner for that. Idk if when they scan it. They could maybe pick something else up. And I would love to give those steps a shot. But I don't have the tools required. And honestly not even sure what exactly I'd need.
  #38
Old 03-02-2016 | 09:24 PM
plumbob's Avatar
Any scanner should read a DTC if present, Autozone will do it for free. If there is a code it may tell you what component needs to replaced. Beyond that, it might be best to have a auto-electric shop check it out.
  #39
Old 03-03-2016 | 12:13 AM
Alex S's Avatar
Ahh. I will try there first I guess. If not i will try and find somewhere to get it checked. All I would need is for them to tell me what part is for sure broken. I have no problem hunting it down. Im just sick of replacing things that aren't broken in the first place ! Haha
  #40
Old 03-03-2016 | 07:19 PM
plumbob's Avatar
Sounds like a plan. Good luck.
