Idle Speed Adjustment
Old Aug 29, 2010 | 08:36 PM
TKG2000's Avatar
Default Idle Speed Adjustment
2002 Chev MC SS - would really appreciate a little help on the where (location) and "how to" of adjusting my idle speed. Thanks!
Old Aug 29, 2010 | 08:40 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
Not very familiar with the '02 models. Are you able to post a pic of the throttle body? I MAY be able to talk you through it.
Old Aug 29, 2010 | 09:01 PM
TKG2000's Avatar
I can but it may take me a while. My understanding it that there is an idle speed control valve - don't know if that can be adjusted - and have heard some suggestion that the only adjustment available is through programming changes. No sure.
Old Aug 29, 2010 | 09:07 PM
On a LOT of cars there is a screw underneath the throttle wire that can be screwed in causing the idle rpm to increase. Again, I am not familiar with the '02 Montes. I would like to help you if I can. Why are you trying to increase the idle speed?
Old Aug 29, 2010 | 09:19 PM
TKG2000's Avatar
I have done that screw adjustment before and I belive it causes some flooding between starts and was only minimally effective. I need to adjust because after doing some engine work, including a performance cam, the idle speed is too low. This causes problems in traffic and sometimes just sitting as it will die unless I compensate with the throttle.
Old Aug 29, 2010 | 09:40 PM
I PM'd you. Good luck.
Old Aug 30, 2010 | 08:52 AM
03SS/00GSE/93LX's Avatar
You'll need to adjust the idle with tuning software like HP Tuners or DHP PowrTuner. The idle speed is controlled by your PCM controlled Idle Air Control (IAC) motor that opens and closes as per PCM instruction to allow air to bypass your throttle blade and adjust your idle.
Where are you located?
Old Aug 31, 2010 | 12:57 AM
TKG2000's Avatar
Excellent! Thank you for the response. I sent you a PM.
Yellow_Monte
May 3, 2021 07:40 AM
ckempfer
Aug 8, 2014 03:46 AM
monte82ppe
Jul 9, 2011 07:13 AM
TKG2000
Aug 29, 2010 08:11 PM
