IAT (Intake air temp sensor)
Old Mar 5, 2013 | 08:50 PM
Default IAT (Intake air temp sensor)
IAT Intake Air Temp sensor
(Located on the intake duct)
Has anyone experienced any issues with this sensor?
If so,
What issue did it cause?
Old Mar 5, 2013 | 08:54 PM
Increase Fuel Consumption
  • The temperature of your vehicle's intake affects the amount of fuel needed to properly operate the car. If the IAT is not working properly, the car's computer may think the car needs a stronger fuel mixture and cause the car to consume more fuel than it normally does.
Read more: Symptoms of a Bad IAT Sensor | eHow.com Symptoms of a Bad IAT Sensor | eHow.com
Old Mar 5, 2013 | 08:58 PM
Thanks Jerry,
Thats where I got the same info from...
I was hopeing someone else would chime in to see if they had higher fuel consumption. and did replaceing it...resolve that issue...
That was my reason for the posting .
Old Mar 5, 2013 | 09:12 PM
Jomao_o's Avatar
Would that sensor throw the CEL if going bad?
Old Mar 5, 2013 | 09:48 PM
Yes....when it fails
Old Mar 5, 2013 | 10:37 PM
nitehawkjcb's Avatar
Your gas mileage would likely decrease if you were running too rich.
Old Mar 6, 2013 | 06:04 AM
aussiek2000's Avatar
Increased fuel mileage would be negligible. Oxygen sensors would cut fuel back once it got warmed up.
TexasDvlDog
Nov 3, 2014 02:54 PM
farmerjg
Feb 7, 2013 10:05 PM
mercury2
Jun 2, 2012 02:59 PM
Shayne_GSX
Jul 20, 2008 08:16 PM
smolek37k
Dec 1, 2007 07:08 PM
