air filter
Old Feb 14, 2013 | 08:42 PM
raspberry619's Avatar
Post air filter
I have a question that im confused on. Will I was wondering if I take my stock air filter of and put a edelbrock air filter on where do I plug up the hoses that were in my stock air filter??? I know some one out there knows so please help and not just read thanks
Old Feb 17, 2013 | 02:42 AM
Maybe you could give us a little bit more info so we can help. What year is your Monte and what size motor for starters. Some pics may be helpful too as possible.
Old Feb 17, 2013 | 03:54 PM
Its a 85 and I have a 350 motor
Old Mar 5, 2013 | 05:59 PM
wvmontels's Avatar
The hose that goes from the valve cover to the bottom of the air box can be replaced by an aftermarket pcv breather. That way, instead of your crankcase air being filtered by the airbox it just has a separate breather. They cost about 10-30 bucks at auto parts stores and just push into your valve cover. Edelbrock breathers have a place on the bottom to put a nipple for this hose also. Some come with the nipple already attached. If you have little vacuum lines I don't know what to do with them. The hose coming off the pcv valve should connect to your carb somewhere. Where at depends on what kind of carb you have.
Old Mar 5, 2013 | 08:05 PM
You could just block off (plug) the small vacuum line.
Also you could just add a breather to the PCV hose... Thus eliminateing the need for the PCV.. (Old School Fix)
Old Mar 6, 2013 | 08:33 AM
Sweet thanks alot you guys
Old Mar 6, 2013 | 09:36 AM
Your very Welcome!
happy to help anytime!
Old Mar 6, 2013 | 12:53 PM
03SSLE's Avatar
You cannot eliminate the PCV system. If you do crankcase pressure will build up and blow out the oil pan and valve cover gaskets. Pressure and residual gases have to be purged from the crankcase. Before emission control they used a vent tube to atmosphere. Then they designed the PCV system which relieves crankcase pressure and recirculates the residual gases through the engine.
Old Mar 7, 2013 | 08:14 AM
oh wow i didnt know that thanks for telling me 03ssle.
Old Mar 7, 2013 | 10:52 AM
Chris:
I wasn't meaning to block off(plug) the pcv..
Just replace it with a breather. Thus eliminating any crankcase pressure build up...Also giving it the ability to still "BREATHE"... I meant the little vacuum hose to plug it that's at the bottom of the stock breather...
I did that to every racing and non racing application on the old style V-8's. Since 1958! Which was a 58 Impala with a 348 tri-power stock from the factory! This was the 1st one I did it to.
Thus the "residual" gases would still be vented off! Making it a non issue.
Maybe, I need to type it more slowly next time?
MonteCarloSS02
Aug 10, 2014 06:08 PM
HIxArsenaL
Jul 25, 2013 09:12 PM
White05LT
Nov 18, 2005 10:03 AM
03SSdriver
Oct 5, 2005 08:13 PM
