I need LED help!!
Old Aug 6, 2011 | 05:05 PM
Chainsaw's Avatar
Default I need LED help!!
OK so I hooked up two LED strips under my dash and hooked them to a switch but when I turn them on, the lights come on but are very dim. I guess everything is hooked up right but why do they come on so dim? I hooked the power up to the top auxiliary post above the battery.
Old Aug 6, 2011 | 05:25 PM
You have a good ground? I had the same problem with my LED undercarage lights but that was I had them hooked up to a source that was not 12volt at first. But where you have them should be 12 volt.
Old Aug 6, 2011 | 10:16 PM
Chainsaw's Avatar
Hey thanks and yeah it turns out it was the switch. I got a new one and now it's working just fine. Sometimes it's the simplest thing...
KingOf206
Dec 25, 2013 07:12 AM
kstinger13
Feb 19, 2012 01:00 AM
Tadcaster
Feb 5, 2012 11:45 PM
srbecker58
Sep 20, 2009 08:30 PM
