I broke this little piece. What is it? 85 SS with BBC
Old May 15, 2012 | 12:41 PM
greenmonster15's Avatar
Default I broke this little piece. What is it? 85 SS with BBC
I was checking to be sure this hose was attached well and broke it. This 85 SS has been changed to a carbureted BBC engine. You can probably see that the piece broke beneath the edge of the air filter, between the carburetor and distributor. In case the video color is a challenge, the wire is purple. I made a video and posted it to youtube.
Can someone tell me:
1. What it is?
2. If possible, can I start the car before fixing it?
3. How to fix it?
Link to video I took on youtube.
Old May 15, 2012 | 03:53 PM
What Big Block Engine do you have ? "348" ? "409" ? ___?
It may help our experts when they view your video...
I don't think it will hurt your engine to start `it ? ?
I can see where it is broke, but I'm not sure what it was connected to...Who did the install of the BBE ? Can you contact that person ?
Please check back on your thread later to see `if one of our Expert Member's can assist...Good Luck
Old May 15, 2012 | 04:37 PM
Can you post a picture of what exactly it is?
Old May 15, 2012 | 07:39 PM
It's hard to tell in the video, where does the other end go?
Old May 15, 2012 | 07:52 PM
I think the purple line goes to your air /heat control panel ..
Looks like vacuum port in manifold behind carb .. just unscrew it an install a new fitting..
you could get a fitting .. if you need more ports for other stuff,
Old May 15, 2012 | 07:57 PM
it definitely looks vacuum related, I just can't think of what it is.....
Old May 15, 2012 | 09:45 PM
I think your right jerry. Also being vacuum related you can run it but it's probably gonna run rough.
Old May 15, 2012 | 09:59 PM
Default Thank you everyone.
Thanks everyone for your help. I'll unscrew that fitting and replace. I'm posting another post in a minute regarding a starting issue. Feel free to put your two cents in on that post too.
johns85mcss
Aug 7, 2015 12:14 AM
izmouse
Mar 20, 2012 03:29 PM
mrl390
Sep 10, 2009 11:18 PM
bbcseeker
Mar 5, 2007 04:17 PM
