Hub Assembly - questions on some details
Old Aug 1, 2011 | 09:22 PM
Stardust's Avatar
Have you done a resistance test on the harness? If it is different from the other harnesses it is probably bad, otherwise it is the connectors.
Same thing happened to me. Check out my other posts and good luck.
Old Aug 1, 2011 | 09:30 PM
Stardust's Avatar
Oh, BTW. Take your breaker bar or ratchet down to Home Depot and go to the plumbing dept. Find a 1 and 2 foot long piece of iron pipe that just fits over the handle to your wrench When breaking a tough bolt just slide the pipe over the end of the wrench handle to elongate it which give you much more leverage. Cheater bars are much cheaper than buying large wrenches and work even better as you can adjust the length to fit the situation. Saves a lot of cracked and bleeding knuckles as well.
Old Aug 2, 2011 | 08:10 AM
Not much to add to this thread, I just want to say NEVER use WD-40 to "loosen" a bolt. It actually lubricates the bolt and you have an increased chance of slipping off.
You need to use a penetrating liquid like liquid wrench or PBlaster to loosen a nut.
Old Aug 2, 2011 | 05:48 PM
great advice Mike, never really thought about it.......
uptownfam
Nov 23, 2010 05:04 PM
teamfbody
Apr 12, 2010 10:18 PM
orthokneepa
Sep 8, 2009 09:19 AM
rgant_19
Aug 14, 2009 08:13 AM
aaronkt
Dec 11, 2008 04:54 AM
