How to wire 4th gen head lights
Old Jun 16, 2008 | 06:19 PM
michael's Avatar
Default How to wire 4th gen head lights
Ihave a problem! I have a 86 ss clone. It was 86 ls and had halogen lamps and changing over to the old school lamp. How do I match the wire? help soon please thank you!
Old Jun 16, 2008 | 07:27 PM
mickey's Avatar
Default RE: How to wire head lights?
2 ways, 1. get the proper harness from a donnar car, 2. go to a auto parts store and get the correct colors for the wires and then wire them the way needed to make them work correctly
Old Jun 17, 2008 | 04:47 AM
michael's Avatar
ok but what color goes to what? the donnar car has differnt colors. test them with a meter and get two diff. power readings? what one is the hot wire? thank you!
Old Jun 17, 2008 | 06:34 PM
mickey's Avatar
take a test light and plug it in to the harness at the socket. plug the ground clamp to a ground. now turn on the lights.
most of the time you have a hot,ground,high beams. park lights.
Old Jun 17, 2008 | 06:36 PM
mickey's Avatar
trun on the park lights and find them . one click on the switch should turn just the parks on.
do the same for high beams and regular beams. as you go write do the colors that turn on the light.
Old Jun 17, 2008 | 06:38 PM
mickey's Avatar
once you figure out the hot wire take a test light with a fuse in line on it.
plug one lead in tot eh wires that dont turn on a light and the others in to the ones that did and mark those down agian and the position of the switch. this will let you know what ground is and the right hot wire for what
Old Jun 17, 2008 | 06:39 PM
mickey's Avatar
sorry for the several post but it wont allow me more then one line or two at a time or i get a erro and it delets everythign on me. your basicaly fishing them out unless you can get a manual for both cars with a wire diogram in them then you could trace it that way and wire the right colors to the car you want from the donr cars harness
Old Jun 17, 2008 | 06:53 PM
michael's Avatar
thank i'll go try that out. You be lot of help! thank You again.
Old Jun 17, 2008 | 07:54 PM
mickey's Avatar
well if ya want bring it to the house and ill help ya out LMAO!!!!!
Heartbeat of America
19
Jun 26, 2014 07:38 PM
Murray137
Oct 20, 2012 08:13 PM
Enzo354
Jan 16, 2012 08:54 AM
Rick ICS
Jun 4, 2010 10:36 PM
YamahaR14
Apr 21, 2008 06:53 PM
