how to remove the shift knob
Old Jun 28, 2016 | 05:12 AM
jptiraboschi's Avatar
Default how to remove the shift ****
How do I replace the stock shifter **** on a 1987 Chevy Monte Carlo?
Old Jun 28, 2016 | 06:44 AM
If the shifter is on the column, it should twist/pull off. If it is on the floor, there will probably be a small set screw holding it on.
Old Jun 29, 2016 | 12:12 AM
It's on the floor and it has a plastic piece in front below the handle. I thought maybe using a flathead screwdriver and pushing down or up to see if it released it from the metal column.
Old Jun 29, 2016 | 06:09 AM
It is very possible there is set screw under that plastic piece that secures the shifter ****. Be very careful because that piece is almost guaranteed to be brittle. Let us know what you find.
