Driver Information Center console - how to remove to check switch
Old Sep 4, 2009 | 11:45 AM
sorcier11's Avatar
Default Driver Information Center console - how to remove to check switch
Hi everyone.
Whenever I either open or close my sunroof on my '04 intimidator, the mechanism seems to pause at times which requires me to fiddle with the switch until the connection works again and the sunroof starts to move.
I'm guessing at this point that the switch might be bad or worse yet, the motor.
How easy is it to drop the DIC from the roof to check the internals?
Thanks in advance.
Old Sep 4, 2009 | 11:51 AM
You may just need to grease the sunroof tracks a little.
Old Sep 4, 2009 | 12:04 PM
sorcier11's Avatar
That alone could cause some of the hesitation while either opening or closing?
Old Sep 4, 2009 | 12:17 PM
If something in the track prevents it from moving completely it could pause, and then you'd have to try to close it more.
It's happened with normal windows, why not a sunroof? Isn't expensive to try and should usually be done anyway.
Old Sep 4, 2009 | 12:31 PM
sorcier11's Avatar
Ok. Failing that, how easy is it to pull the DIC from the headliner?
milrlyt
FWD Tech Guides '95-'07
Aug 24, 2022 06:54 PM
paintballerr78
Sep 11, 2009 12:26 PM
