> How long does a Auto Battery Last ? + more auto tips <
Old 08-17-2013, 08:30 AM
Question > How long does a Auto Battery Last ? + more auto tips <
Hi Member's,
How long did your battery Last ?
What kind ? What is the best to have ?
Tell us about it `OK > Share
<table id="top_images" style="font: 15px/normal Verdana, sans-serif; width: 972px; text-align: center; color: rgb(0, 0, 0); text-transform: none; text-indent: 0px; letter-spacing: normal; padding-top: 20px; margin-top: 0px; margin-right: 0px; margin-left: 0px; word-spacing: 0px; white-space: normal; font-size-adjust: none; font-stretch: normal; background-color: rgb(255, 255, 255); -webkit-text-stroke-width: 0px;"><tbody><tr><td></td><td></td><td></td><td></td></tr></tbody></table>Car Battery Life - How Long Does a Car Battery Last
Battery life is defined as the period of time in which a battery is capable of being recharged and retains the charge applied. Once the battery is no longer capable of being recharged or cannot retain its charge properly, its useful lifetime reaches its end. The main cause of this "death" is the sulphation process. This begins when lead sulphate precipitates over the battery plates, coating them and preventing the reactions which produce the electric energy.
The life-span of all batteries is linked to the capacity of the battery (e.g. in Ampere hours) and the amount of current (Amperes) drawn from the battery by the device which it powers. Temperature, humidity and other environmental factors also have an impact on battery life-span.
Under ideal conditions, one automobile battery can last up to six years, but several factors decrease this optimal lifetime. A study of 2,769 sample 12 volt batteries conducted in 2004 showed that the average lead acid battery life is 50 months. Batteries in the northern US had an average life of 56 months compared to those in the south which had an average life of 43 months. Lead acid batteries last longer in cold climates as warm climates increase water loss and sulfation. Car battery life span range is 2 to 5 years.
The most simple and effective way to extend the life of an automotive battery is to keep it charged close to 100%. Periodically check the state of charge of your battery (see How to measure open circuit car battery voltage) and charge it with a dedicated charger device when necessary (see How to charge a car battery). Consequently, try to avoid deep battery discharges that can happen, for example, if you leave your car's lights on.
Hybrid car battery life expectancy and electric car battery life expectancy is about 8 years.
Old 08-17-2013, 08:39 AM
Sitting at the Chevy hospital right now getting the 2nd battery in7 years
They told me to take. It out in winter when I store the Deuce
Even with a trickle charger it still can freeze they tell me
Old 08-17-2013, 08:47 AM
Hi `Tadd, I just posted about your battery in 2day's Blog...
I guess you will just have to heat your Garage for your `Deuce
She's worth `it....4-Sure
Old 08-17-2013, 08:50 AM
I'd love to do that Space
Old 08-19-2013, 04:34 AM
Hi `Tadd, your Deuce deserve to stay warm & cozy during your cold winter months...If it were mine, I'd sleep in the garage with it
Old 08-19-2013, 08:33 AM
03SSLE's Avatar
It must get awfully cold in your garage if the battery is freezing with a battery tender connected to it.
Old 08-19-2013, 08:45 AM
My original ACDelco lasted 8.5 years on the Monte. I was amazed it lasted all those years and well over 150,000 miles.
Seems like the average life is around 5 years.
Old 08-19-2013, 09:19 AM
Thanks Member's for your posts/infor...Admin `Mike, that's amazing that it lasted that long 4-Sure...*I think it's because you never shut it `off >
<header style="margin: 0px; padding: 0px; outline: 0px; border: 0px currentColor; font-size: 13px; vertical-align: baseline; display: block; background-color: transparent;">How to Test a vehicle alternator with a standard multimeter
<aside class="fl" id="article-sidebar" style="margin: 0px 0px 0px -92px; padding: 0px; outline: 0px; border: 0px currentColor; width: 62px; height: 0px; overflow: visible; font-size: 13px; vertical-align: baseline; float: left; display: block; background-color: transparent;">222
KUDOS
</aside></header><aside class="clearfix" id="abatf" style="margin: 0px; padding: 0px; outline: 0px; border: 0px currentColor; font-size: 13px; vertical-align: baseline; display: block; -ms-zoom: 1; background-color: transparent;"> Click above for vid plus More Great Tips on above site
</aside><section style="margin: 0px; padding: 0px; outline: 0px; border: 0px currentColor; font-size: 13px; vertical-align: baseline; display: block; background-color: transparent;">Richpin demonstrates how to test an alternator with a standard multimeter. First make sure that the vehicle's battery is fully charged. Take the negative lead of the multimeter and put it on the negative post of the battery. Place the positive lead of the meter on the positive lead of the battery. Set the meter to DC voltage using the 20 scale and read the display to ensure the battery is fully charged. Next start up the vehicle and see what the alternator is producing. The display should now read one volt over the initial reading. If the reading remains the same, then the alternator is not producing any electricity. Now, turn on the lights and heater blower to see, if the alternator is weak. Let the car run for a while and if the display holds its reading, then the alternator is working fine.
</section>
<iframe name="lbIframe" id="lbIframe" frameborder="0" style="display: none;" classname="grey"></iframe>
<img id="lbImage" classname="grey">
Old 08-19-2013, 09:29 AM
What Could Go Wrong When Spraying Primer?
So you're ready to spray primer on the car you've been working hard on. You're almost ready to paint and complete the job. SO w...
How to Block Sand Primer Surfacer
There are a lot of do's and don'ts when it comes to block sanding the primer surfacer on your car. In fact, this can make the d...
Will Dry Ice Work for Dent Repair
I have always heard about how dry ice can repair dents. I have been asked this question, so I put it to the test. I got some dr...
Will JB Weld Repair a Cracked Engine Block?
I went to get my boat ready for the summer and discover that my engine block was cracked. I looked online to find the cost of a...
How to Restore Your Headlights Using Toothpaste
Yellowed or hazed headlights don't only make your car look tacky, it also reduces the amount of light that can shine through at...
Old 08-19-2013, 10:17 AM
Ya pretty cold here in winter. I am looking at that heater Space posted I am wondering how much is costs to run
Quick Reply: > How long does a Auto Battery Last ? + more auto tips <
