How do I wire my fog lights (HIDs) with a Relay?
Terminal 30 provides power to the ballasts through terminal 87 when the trigger circuit (85/86) is energized. To complete the circuit you need to ground the ballasts according to the manufacturer's recommendation. This is usually directly to the frame/body but check your info about the ballasts first. If it doesn't work after that you need to go back and double check your work and the proper operation of the switch/relay/ballasts.
You don't have the ground from the HIDs coming back to the switch do you?
Are you switching the lamps BEFORE or AFTER the ballast? I can see switches going bad with 23,000 volts going through them.. But as for the wiring, use 12 or 14 gauge wire all the way around, and consider using wire loom for extended lengths. And the schematic isn't supposed to say 35KV, it's supposed to say 23KV. I was thinking 35W.
pizzarrhea
Oct 6, 2009 09:36 PM
