How do I clear EVAP I/M monitor, w zero DTC codes showing
Old Apr 5, 2012 | 04:50 PM
8car2002's Avatar
Default How do I clear EVAP I/M monitor, w zero DTC codes showing
I started off with P420 code, replaced the O2 sensor, no changes, next replaced the CAT, then P420 code went away, but the I/M Monitor for the O2 and Evap came on, say 2 incomplete and 6 ready. Smog guy said to add more gas and may change the cap too and drive it longer, so i did it all and the O2 I/M Monitor went away, so now at 1 inc and 7 ready. How do i get the EVAP I/M monitor to show ready? It doesn't work to just clear the codes on the OBD II scanner for I/M monitors...How long do is a drive cycle for EVAP to show ready? Disconnect Battery? How long?
2002 MCSS
Thanks,
Evaporative System Monitor
Ready
Vehicle was driven enough under proper conditions to
complete the monitor.
Inc
(Incomplete) - Vehicle was not driven enough under
proper conditions to complete the monitor.
Old Apr 6, 2012 | 06:40 AM
03SSLE's Avatar
In order for all monitors to be placed into the ready state a drive cycle fitting all the following criteria must be met:
General Motors Driving Cycle
Hope this helps...
Old Apr 9, 2012 | 04:23 PM
8car2002's Avatar
Thanks 03SSLE, i going to give a try in the morning, only thing is ..my A/c doesn't work....we'll see how it goes...........
RickCoMatic
Jun 18, 2015 06:05 AM
03SSLE
Jan 7, 2012 07:03 AM
thomasnchy
Sep 23, 2008 06:20 PM
2003 SS
Jul 4, 2008 07:51 AM
Great White North
MCF Website Problems & Issues
Apr 28, 2006 10:44 AM
