6th Gen ('00-'05): horn troubles
Old Mar 11, 2016 | 02:23 PM
gferg44's Avatar
Question horn troubles
2002 Monte SS 3.8 Horn will only work if the steering wheel is turned and even then is intermittent. Have traced it back starting with the horns themselves, relay, fuse, I installed a new clock spring.....there is a plug in beneath the clock spring assembly....white with a spring in it....does this or it's contact have something to do with the horn not working properly? any assistance is appreciated
