Hood Won't Open
Old May 19, 2014 | 01:31 AM
Austinho_4's Avatar
Default Hood Won't Open
So spontaneously my hood lever stopped opening the hood. It's as if the lever isn't even connect when I pull it, I can hear a noise in the hood like the wire is trying to pop it open but it's not popping open. Anybody ever have this happen to them before? Any advice? Thanks guys
Old May 19, 2014 | 02:08 AM
Habbibie's Avatar
Have someone punch on the hood where the hinge is while you pull on the lever. It'll pop open it's just sticking. After you open it soak the hinge with WD40 so problem won't persist.
Old May 19, 2014 | 02:54 AM
Austinho_4's Avatar
Shoot, the thing is that I already tried it. Wiggled it,
Moved it up & down; finessed it and it still hasn't opened
Old May 19, 2014 | 02:55 AM
Austinho_4's Avatar
Old May 19, 2014 | 07:23 AM
Here is a video on another way to open a Monte Carlo's hood, skip to 7:45 and see it's still hard to open even with one of these.
But in all seriousness, I don't have a clue as I spoke to my mechanic before about this scenario and he said it would be very difficult. Keep us posted as to how you finally get her open. Unfortunately your it! Get to be our guinea pig test car. Really hope it is not as big as an ordeal as in the video...
See video link:
Old May 19, 2014 | 11:20 AM
Habbibie's Avatar
You can attempt getting at the hinge from the bottom of the car
Old May 19, 2014 | 02:24 PM
03SSLE's Avatar
This is for a B body, but it might be applicable to the W body as well...
how to open monte carlo hood with broken cable - Bing Videos
Old May 19, 2014 | 04:21 PM
Austinho_4's Avatar
See video link:
Fuel-Fed Car Fire: Chevrolet Monte Carlo Driver Smells Gas, Hears Poof While Driving - YouTube
Man, why did you even share that; that's horrible! Such a beautiful car, lol. But dang, I see. Yeah I'm going to ask a mechanic or somebody at AutoZone maybe that could help out and I'll definitely let you guys know the resolution.
Old May 19, 2014 | 04:23 PM
Austinho_4's Avatar
Thank you Mike, I appreciate that reply & the video along with it. I check under there but wasn't able to find the backup lever that the guy reached up in between there for. I was able to look at a few other things and will thoroughly try all of the possibilities tomorrow once I'm able to get a little free time. I feel that I'm getting closer to a solution though.
Old May 24, 2014 | 08:26 PM
Austinho_4's Avatar
Alright guys, I figured out what the problem is. So the cable that is connected to my good release and the lever to pop it open under the hood is overstretched. Meaning that the hood release doesn't pull the cable far enough to open the lever to pop open my hood. I have to buy a new cable through a dealership to get it replaced. In the mean time what I can do to open my good is disconnect the cable from the good release and use a pair of pliers to pull the cable far enough to open my hood. If you have the same problem do this, but be sure to pull the release all the way and then pull the cable with the pliers.
