High idle
Old Feb 5, 2009 | 02:26 PM
bgrd84's Avatar
Default High idle
I have a 95 Z34 Monte Carlo. It idles at about 2,000rmps in park and neutral. It has had the head and intake gaskets replaced. The check engine light comes on and stays on for a while then shuts off and comes back on again. any ideas as to what would cause these issues?
Old Feb 6, 2009 | 11:22 PM
sebcar's Avatar
Default RE: High idle
What engine do you have? dose it idle high at a constent rate or does the rpm needlemove around, like it gose form 900 to 2,000 then 1,500, and keep bouncing around like that untill you put it in Drive?
Old Feb 8, 2009 | 08:37 AM
bowtietech's Avatar
Does your Monte have the 3.4X overhead cam engine? Did the high idle issue start after the head and intake gaskets were replaced? A vacuum leak could cause a high idle like you describe.
Old Feb 11, 2009 | 08:31 AM
bgrd84's Avatar
ORIGINAL: sebcar
It has 3.4l overhead cam. the needle jumps around. It does almost exactly waht you just said. This problem atarted after the intake and head gaskets were replaced. How do I find the problem if it is a vacum leak?
Old Feb 11, 2009 | 10:24 AM
sebcar's Avatar
Did shop that changed your head and intake gasket change your spark plugs?
Old Feb 15, 2009 | 09:22 AM
bgrd84's Avatar
ORIGINAL: sebcar
Im not sure if the plugs were replaced or not, but the wires look newer. We just bought the car. It also has a hard time starting only when its cold. At 70mph the tack reads around 3000. Is that normal?
Old Feb 15, 2009 | 10:50 AM
kweef's Avatar
i would have to agree that its most likely a vacuum leak even tho the gaskets have jsut been replaced.
victoryred05
Mar 2, 2023 01:12 PM
mattilus2121
Feb 22, 2009 10:45 PM
SpaceAce
Dec 16, 2008 10:03 PM
vegav6
Apr 14, 2007 09:00 PM
shawner
Mar 8, 2006 03:27 PM
