1996 Monte Carlo has high idle
Old Dec 15, 2008 | 01:47 PM
SpaceAce's Avatar
Default 1996 Monte Carlo has high idle
I have a 1996 Monte Carlo that will idle aroung 3000 rpm on start up and will not come down unless you turn engine off and re-start. I have noticed even then, if you are sitting at a stoplight or something that it will surge every once in a while. I can access the OBD, but there are no codes being thrown out.
Any ideas?
Old Dec 15, 2008 | 03:59 PM
Default RE: 1996 Monte Carlo has high idle
[align=center]Hi SpaceAce & Welcome to the MCF Family.[/align][align=center](Good MCF Name: )[/align][align=center][/align][align=center]If it is not throwing any codes I[/align][align=center]suspect it could be a faulty idle speedsensor. [/align][align=center][/align][align=center]I would also check your `Cat to made sure it is not clogging : ([/align][align=center]Also I would clean your Mass Airflow sensor.[/align][align=center][:-][/align][align=center]Check back later 2 see what some of our expert members[/align][align=center]post about your problem.[/align][align=center][/align][align=center]Have you ever used a product called Sea Foam ?[/align][align=center]It cleans your system. To read about it, just do a[/align][align=center]Googles Search & type in > Sea Foam[/align][align=center]Click on below link[/align][align=center]Sea Foam
SEA FOAM MOTOR TREATMENT Solving Engine Problems Easily and Inexpensively! Consumer information. Technical information for gas engine applications, ...
www.seafoamsales.com/motorTuneUp.htm - 25k - Similar pages
[/align][align=center]Check back for solutions fromsome of our Expert Members.[/align][align=center]Good Luck & let us know if you fix your problem.[/align][align=center][/align][align=center]Happy Holidays,[/align][align=center]`Space[/align][align=center][/align][align=center][/align]
Old Dec 15, 2008 | 04:56 PM
SpaceAce's Avatar
Is the Idle Speed Motor the same as the Throttle Postition Sensor, Idle Air Control Valve or Vehicle Speed Sensor? Maybe it is none of the above mentioned. I just wanted to know because sometimes they are called different things and I can't seem to find anything called the Idle Speed Motor in my breakdown manual.
Thanks
Old Dec 16, 2008 | 10:18 AM
Cowboy6622's Avatar
the idle air control valve is what 'Space mentioned i believe.
my first thought was a clogged kitty under the car (i call the catalytic converter a kitty sometimes).
does it feel like it's weak on power or anything? does it surge any going down the road?
3000 rpms is too high for a start... you definitly need to look into the problem.
lots of times a clogged cat won't set off a check engine light.. i think the idle control vavle would, so i'm leaning towards the clogged cat.
Old Dec 16, 2008 | 11:01 AM
SpaceAce's Avatar
Thanks Guys, I will look into both. One more thing though, if the Cat was clogging why would the the re-start bring the idle down [even though it is still a little high (~2000 rpm) and still won't kick down after warmup].
Old Dec 16, 2008 | 08:44 PM
Cowboy6622's Avatar
I don't know the answer to that question.... I just know that weird and crazy mess happens when cats clog. There are, however, other possiblities, as 'Space mentioned.
Old Dec 16, 2008 | 10:03 PM
scc24540's Avatar
check this in this order
1. air temp sensor- its in the intake tube
2. AIC (idle air control) valve- its on the back of the throttle body
3. TPS (throttle position sensor)
4. vacuum leak
5. manifold vacuum sensor- its a black box on the back of the intake
if any are clogged or defective let us know
victoryred05
Mar 2, 2023 01:12 PM
Dustin LaRoche
Jan 27, 2012 04:35 PM
homerunswing
Jun 24, 2010 08:17 AM
vegav6
Apr 14, 2007 09:00 PM
shawner
Mar 8, 2006 03:27 PM
