HI new to forum! Can anyone help me?
Old Jul 14, 2013 | 12:39 AM
chevy freak's Avatar
Default HI new to forum! Can anyone help me?
My buddie got an 87 monte carlo with the 4.3L v6 in it. when we got the car all vacuum hoses where gone and everything was block off. the only vacuum hose connected was the egr. Now iv been working on it for a week now. the issues im having are the following..
1.. the car wont rev over half throttle unless i play with the vacuum stems on the TPI
2.. I didnt know if there should be a starter shim on the starter because it sounds like its spinning with flywheel but noise goes away when i rev motor.. sounds like loud vibrating coming down by starter and flywheel.
i have replaced the flywheel because it was chewed up from previous owner. I also changed the starter at the same time but didn't come with any shims.
i gave the motor a full tune up, pluges wires distributor cap rotor fuel filter clutch fan. i timed it and i still cant get it to rev over half throttle. only if i play with the vacuum on TPI. anyone have any idea???
Old Jul 14, 2013 | 08:22 AM
I am not able to answer your questions but I thought I would say "welcome to the Forum" to bump this thread up so one of our more experienced members would see it
Hope you get that Monte straitened out soon!
Old Jul 14, 2013 | 02:51 PM
03SSLE's Avatar
With that history I'd say you have a vacuum leak being caused by either improper routing or missing hoses/components. There should be a decal under hood that shows the vacuum hoses and there routing. If not you may find one searching the web. You could also have a fuel related issue, but you need to insure all vacuum hoses are installed and routed properly first, then see how it runs and go from there.
Flywheel (manual trans) or Flexplate (auto trans)? If it is loose, bent or cracked that could cause noise and vibration. So could improper balance, a loose torque converter, a bent inspection cover, a bad starter solenoid and the list goes on. Since you replaced the flywheel/flexplate my suggestion would be to double check everything. Was the replacement the same size and number of teeth? Was it balanced if needed? All bolts torqued to spec? Starter/Solenoid in working condition? Anything (like bent inspection cover) obstructing flywheel rotation?
And welcome to the forum.
Edit: Also check for vacuum leak at TPI mounting.
Old Jul 14, 2013 | 11:20 PM
Welcome to the site.
Old Jul 15, 2013 | 10:26 AM
the motor was completely de vacuumed and and cap off. yes there is a diagram but its mission most of the components, all emissions for car is taken out.. aftermarket air filter is on it. jw if a tps sensor would cause the car to loose power half throttle.
Old Jul 15, 2013 | 10:48 AM
03SSLE's Avatar
Yes, a TPS could cause the problem, but if the vacuum lines have been rerouted (components removed) and you can get the engine to accelerate when you manipulate the vacuum hoses at the TPI that leads me to believe you have improper routing, a vacuum leak or vacuum is not being applied where and when it needs to be. You'll need to try and route them as they were originally - especially those at the TPI and any that were routed through thermal vacuum switches.
Old Jul 19, 2013 | 09:32 PM
Tazz76's Avatar
I have a 86 I can send u some pictures of the vacuum routin I u need it
Old Aug 15, 2013 | 08:42 PM
wvmontels's Avatar
It sounds to me like the starter and flywheel ain t got the same amount of teeth for your starter problem.
BlackRainSS
Nov 23, 2011 04:17 AM
Blazed SS
Jun 22, 2010 09:52 AM
lucian*91
Jun 10, 2010 09:18 PM
vincentvega
Jun 10, 2007 02:06 PM
