help - sticking brakes after pad change
Old Sep 28, 2010 | 07:14 PM
mini64's Avatar
Default help - sticking brakes after pad change
changed the front pads on our 2003 and now they are getting really hot, and act like warped rotors. what could i have done wrong?
Old Sep 28, 2010 | 07:37 PM
Chevy Commando's Avatar
On the caliper there is a rubber boot, one per bolt...total of two per caliper. Either it is missing or there is no grease in there and it is sticking. I would check that. If the boots are on then I would grease the bolts up so the caliper will move freely.
I had that happen on my 04. The boots was missing on one caliper and replaced both the pads and rotors then it started sticking. My friends and I replaced the boots and greased the bolts and it now works like a champ. I guess it could move just euff that on the old set it never stuck but on the new set it did. I hope this helps.
Old Sep 28, 2010 | 10:42 PM
lucian*91's Avatar
you will warp your rotor if tire isnt torqued evenly, use a star pattern and torque to 100ft lbs each. buy a bar style torque wrench if needed $20 craftsman part
Old Sep 29, 2010 | 12:58 PM
mini64's Avatar
I torque them evenly when I do it. Discount tire does not. Nevertheless I've checked disc runout and its no more then mabye 2 thou. With the bolt pattern so close to the thick hub it seems like it would be hard to warp these. easier on some other cars.
Tahj Mahal of Atlanta
Nov 27, 2014 07:18 PM
TheVille87
Apr 15, 2014 07:02 PM
03JGMonte
Aug 10, 2011 02:50 PM
goingforgold
Dec 17, 2010 06:16 PM
Endo
Mar 9, 2010 12:14 PM
