6th Gen ('00-'05): Help Please, power steering loosing power
Old Sep 7, 2016 | 12:49 PM
Storman1's Avatar
Unhappy Help Please, power steering loosing power
Hi everybody did a complete u turn the other day in a parking lot, when I turned the wheel back to straighten out the power steering quit and I had to muscle wheel back. I stopped at the stop sighn, and had full power back. happened again later. when I got home checked P.S.fluid level it was fine. it looses power during tight turns from either direction if I stop it comes back
Old Sep 8, 2016 | 04:12 PM
jakefluker's Avatar
Sounds like something with power steering hose if doing it on tight turns. Common issue with your year Monte probably will need to change power steering pump (could be going bad)
Old Sep 11, 2016 | 02:35 PM
Storman1's Avatar
Thanks jakefluker that is what I'm thinking, its a 2000 185000 miles leaks every where I added about 6 oz. of fluid when I got home so far so good. Thank you for replying
Old Sep 28, 2016 | 10:59 AM
Storman1's Avatar
up date power stearing pump replaced took 2 hours, worked for 15 mi. then back to the same. dropped it off at mechanic, they replaced pump again under warranty, same problem, so the rack gets replaced. I had not seen my car since I dropped it off, when I got there I looked at the car, and front drivers bumper has had a small impact with some thing yellowand left yellow paint on side of fender. the owner says it came in that way. I advised him on Friday I had washed the whole car to get greasy hand prints, and my friend that helped me, dropped it off told them the same I helped wash it to no damage, any way the stearing was fixed with the rack, but very loud whine, stopped by a friends shop that I don't usually let fix my cars, hard to be a close friend to your mech., his tech came over listened to the whine, asked if they had vacuumed the system, I told him that they said it wasn't necessary and didn't have tool, its going back to my friends shop to get vacuumed next week. called the other shop to ask again if he had checked the security cam yet from that Saturday at 10:30 to eleven and he was very rude that he didn't have time for that. when I told him the pump was whining he hung up. I will up date after the system is vacumed , Thanks for the help and ideas
Old Sep 28, 2016 | 11:25 AM
owens91's Avatar
They should care what happened to the car that's a lawsuit
Old Sep 28, 2016 | 02:22 PM
turbo monte's Avatar
Yep, lawsuit in my book
Old Sep 29, 2016 | 01:54 PM
Storman1's Avatar
Thanks guys, that's what is coming, A Army buddy is a investigator for popo he is going to lean on him. Leaving scene of accident with property damage is a felony, so hes, going to inform him that if it was a employee of his did the damage he will be charged. He's giving him 10 days to fix the problem or will take the video with him.AS far as the car its going to sit until I save some money to have it purged replace pump again and have it vacuumed filled, Ill get back to the board when done
Old Sep 29, 2016 | 04:56 PM
jakefluker's Avatar
Wow sorry to hear that. I had similar incident 2 wks ago when I had oil filter adjusted and new parked my car and went to get out swung door out and hit pick up next to it causing a big chip in my paint. he apologized etc. but I had to let owner of shop know about, long story short owner wrote check for cost to repair/repaint $270.00 but there was no hassle whatsoever. Been going shop for long time and he's a good honest guy. Still some honest repair shops out there, but not enough!
Old Sep 29, 2016 | 05:25 PM
You bet we would be in court if anyone ever treated either of my Montes that way!!!
Old Oct 1, 2016 | 10:43 AM
Storman1's Avatar
the detective, went by the shop, about 3pm the owner called me to and very nicely asked me to get 2 estimates. The detective( old Army friend) said he had a great time making him squirm. Still don't know if flushing all the fluid and filling by vacuum will stop the whine at high RPM about 3g
