6th Gen ('00-'05): Help please!!
Old Nov 25, 2016 | 10:03 PM
nitehawkjcb's Avatar
That's pretty high for 60 MPH IIRC. Sounds like either a TC issue or perhaps the solenoids in the replacement transmission, especially the one for the TC clutch, could be your issue. I have also heard of a bad brake switch causing a no OD scenario.
Old Nov 26, 2016 | 02:17 AM
Sarah Marry-Poppins McDermott's Avatar
My old transmission did the same thing. I'm having bad luck with the car. The problems never seem to end and I've only had it for a year
Old Nov 26, 2016 | 01:43 PM
RickCoMatic's Avatar
Old Nov 26, 2016 | 02:01 PM
plumbob's Avatar
I thought of the 4th clutch hub too, but it seems awfully coincidental that both trans. would have the same problem.
As for the P1811, Sarah said there are no codes. This would also rule out the TCC solenoid since it should throw code P0743, or code P0740 or P0741 for the TCC circuit.
A bad brake switch would throw codes P0504, P0703, or P0719.
