6th Gen ('00-'05): Help needed ASAP electrical issues?
Old Apr 28, 2014 | 05:13 PM
WImonteman's Avatar
Default Help needed ASAP electrical issues?
Hey yall, im having an issue with my 2000 Monte Carlo SS. I believed it was the alternator but I now fear I have an electrical issue. When I go to start the car it will not start unless everything including the dome light is off. Is this a wiring issue or could it be a bad fuse/battery cable. I did temporarily fix a stripped battery and wire screw with a new battery and a bolt to hold the positive wire on. Could that be my issue?
Old Apr 28, 2014 | 05:57 PM
Its pretty obvious that its a connection issue at the Battery...
It may also be the Battery...
Since the clamp is not longer functional on the cable....that attaches to the battery...
I would replace the bad cable.
That would eliminate the screw/bolt issue!
Old Apr 28, 2014 | 08:30 PM
WImonteman's Avatar
alright I got the full cable switched so hopefully the problem stops but we shall see. thanks Stumpmi
WImonteman
Feb 16, 2015 11:17 AM
Hiroska
Nov 28, 2014 09:48 AM
ruthilldude
Jan 16, 2013 06:28 PM
dbellis03
Oct 11, 2011 09:16 PM
zk6216
Mar 11, 2008 11:19 PM
